It is currently Wed Jul 30, 2025 12:34 am
PostPosted: Fri Aug 12, 2005 4:38 am
I am spraying KTM-9 with a big compressor and a finish HVLP gun. The coats are going on even but the don't seem to flow out any...it's almost like they are drying too fast! The humidity is 45% in my spray area. I'm using about 50lbs. of pressure. Help!!I'm between coats. Any suggestions or soulutions?? The texture is like fine sandpaper. It never looks wet while I'm spraying.
PostPosted: Fri Aug 12, 2005 4:48 am
I had this happen, I opened up the nozzle that allowed more lacquer to come through and backed down my pressure to around 40lbs.
i also use a harbor fright touch up gun, 19.99 cheapy.
Hope this helps
PostPosted: Fri Aug 12, 2005 6:27 am
I have my best results at 35 psi. I too use a touch up gun
PostPosted: Fri Aug 12, 2005 6:49 am
I agree...get the pressure down. But, I don't think you would notice any issues once you sand it back and buff it out. You don't need a "wet" coat with ktm9.
PostPosted: Fri Aug 12, 2005 7:09 am
I will try turning the pressure down and let you know the outcome.
Users browsing this forum: Bing [Bot] and 7 guests
